I don't see Master Volume level in VDJ 2018, Default Skin for Mac OS.
Did i miss something?
Is there a setting or button to enable it?
Thanks
Thanks
geposted Fri 31 Aug 18 @ 10:51 am
geposted Fri 31 Aug 18 @ 12:08 pm
Thanks, found it.
But Master Panel does not respond to either Master volume or headphones, Cue/Master control on my controller. Although those controls work in reality - Master Volume, Headphones and other levels react accordingly.
Denon MC6000 on Mac OS High Sierra (MBP Pro 2015)
Here is my Audio Settings page
geposted Sat 01 Sep 18 @ 11:18 am
Read the manual...
https://www.virtualdj.com/manuals/hardware/denon/mc6000/index.html
Some controls are hardware only - they don't send MIDI, so the knobs on screen won't move. If you have the real thing in front of you, there's no need to have or use those same controls on screen.
geposted Sat 01 Sep 18 @ 12:02 pm
Yes, but in VDJ 7 on the same computer Master Volume level knob moves the same virtual knob. Also, on another skin it does show Master Level in numbers from 0-100. That made it easier to adjust Master level. That's why I'm asking.
Wonder if this issue is prevalent with other Midi DJ controllers.
Is there a way to fix it through mapping?
geposted Mon 03 Sep 18 @ 3:39 pm
Read the manual...
Quote :
Some of these elements offer MIDI notes and they can be used for your own mapping needs. These elements are not used in default mapper of VirtualDJ
geposted Mon 03 Sep 18 @ 4:58 pm
We will fix this in a future update, but in the meantime do this..
- Assign MASTER_VOL key as..
- Change the ONINIT key from ..
- Change the ONEXIT key from ..
Useful info : Custom Mapping
master_volume
deck 1 filter_activate off & deck 2 filter_activate off & deck 3 filter_activate off & deck 4 filter_activate off & mixermode ? nothing : fake_mixer on & fake_eq on & fake_gain onto ..
deck all filter_activate off & fake_master on & mixermode ? nothing : fake_mixer on & fake_eq on & fake_gain on
deck 1 filter_activate on & deck 2 filter_activate on & deck 3 filter_activate on & deck 4 filter_activate on & mixermode ? nothing : fake_mixer off & fake_eq off & fake_gain offto ..
deck all filter_activate on & fake_master off & mixermode ? nothing : fake_mixer off & fake_eq off & fake_gain off
geposted Tue 04 Sep 18 @ 7:13 am
Done. Thanks!
Now I need the skin, which would show Master Volume level in digits. :)
geposted Fri 07 Sep 18 @ 4:38 pm
