Is the DJM-750MK2 mixer supported by VDJ? I cant get the sliders to move within VDJ as Im using the mixer. Any help is appreciated. Thanks.
geposted Tue 11 Sep 18 @ 1:13 am
No, the MK2 is not natively supported. You could either use/map it as Simple Midi or create a custom definition
geposted Tue 11 Sep 18 @ 1:42 am
If you have a real hardware mixer, you don't need to use the 'virtual' mixer on screen....
geposted Tue 11 Sep 18 @ 9:55 am
