Hi folks, when using the automix to have a playlist, Occasionally if i accidentally double click on another playlist saved it loads in the automix and erases the previous playlist! Is there anyway to stop this from happening ? Thanks
geposted Mon 17 Sep 18 @ 10:43 pm
Best solution is: Just don't double click on another playlist ;P
But if it still happens. Just double click on the previous playlist and it'll load it back to the automix list.
geposted Wed 19 Sep 18 @ 8:03 am
You need to do it or not, but it would be possible to create a kind of safe mode to before the instant mix playlist will be loaded the new list was a warning. Protection from fool! or rash action such as double-click.
geposted Wed 19 Sep 18 @ 8:49 am
Try adjusting the double click timing on your computer (so you don't have accidents)...
geposted Wed 19 Sep 18 @ 4:40 pm
It's not a big deal. Just double click the previous playlist. It will get loaded into automix and continue at the same spot as before accidentally loading the wrong list.
Even music doesn't stop because the currently playing track isn't affected by loading another playlist.
geposted Thu 20 Sep 18 @ 7:34 am
