Any chance of a future version of VDJ with 64bit support. Next month I am going to pick up a spanking new AMD Athlon 64 3200+ Clawhammer 400MHz FSB. Running on WinXP 64 bit version. Yes I know this processor will already support a 32 bit program from the get go. I was just wondering if there was any future plans to make VDJ 64 bit.
Thanks.
Regards;
Redman247
Thanks.
Regards;
Redman247
geposted Mon 27 Oct 03 @ 10:51 am
Redman, If the soft can comfortably perform all the features it's designed for in 32 bit mode, what would be the advantage of vDJ running in 64bit mode ?
geposted Mon 27 Oct 03 @ 2:34 pm
I am thinking about multiple instance stability, and less use of the resources to do it. Exspecailly if it were possible to link two instances to each other.
geposted Mon 27 Oct 03 @ 2:53 pm
