Hi,
when I bend (or slow down) using the !! LEFT!! jogwheel of my ddj-sb3 there are crackling sounds hearable.. Only the left deck has this issue.
I recorded it and posted it on soundcloud. (last 3 seconds of recording it's best hearable)
https://soundcloud.com/magic-d/test-2
Does anyone know what happens here? It is really only the left deck, right deck plays fine.
Thanks, Chris.
Thanks, Chris.
geposted Wed 19 Sep 18 @ 7:53 am
Sounds like your latency is set too low
geposted Wed 19 Sep 18 @ 9:09 am
sounds like a latency issue
PC https://virtualdj.com/wiki/PC%20Optimize.html
MAC https://virtualdj.com/wiki/Mac%20Optimize.html
geposted Wed 19 Sep 18 @ 9:10 am
Yes, thought latency as well but latency checker defines my machine as perfect. Used the build in soundcard of the SB3, not via my computer...
Must say, turned the controller off and on again and it was gone, but not sure if the problem is gone permanently.
I'll make sure I go true the list you provided and ask again when this isn't the issue.
Thanks!
Thanks!
geposted Wed 19 Sep 18 @ 1:50 pm
That may be, but you still need to set the correct latency for your audio interface.
geposted Wed 19 Sep 18 @ 4:29 pm
Ah ok, and if I'm right that's possible in the vdj software. Please correct me if I'm wrong here :-)
geposted Wed 19 Sep 18 @ 6:14 pm
VDJ has some settings that affect latency, yes - but you need to adjust the buffer size of your ASIO driver.
geposted Wed 19 Sep 18 @ 6:23 pm
OK thanks!
geposted Fri 21 Sep 18 @ 9:10 am
