Topic: Cueing just through headphones please?
BennyG4Home userMember since 2018
Hi guys
I have a Pioneer Xdj Aero and I'm running VDJ8.2 on Windows 7. When cueing I can use headphones just fine; I can hear the mix from deck 1 and/or 2. What I can't fathom is how to stop everyone else hearing what I'm cueing through the speakers. I'm using headphone socket on the front of my controller and speakers are master out on 1/4" jack's. Audio settings are factory set.
Any suggestions?
geposted Sat 22 Sep 18 @ 10:31 pm
Try posting a screenshot of your audio setup page
geposted Sun 23 Sep 18 @ 2:17 am
geposted Sun 23 Sep 18 @ 8:09 am
You may need to install ASIO drivers for the XDJ Aero, it appears the WASAPI driver only has 2 (mono) output channels
geposted Sun 23 Sep 18 @ 8:17 am
The ASIO drivers are installed. I'm pretty sure I need to set the audio setting up, but unsure what they should be.
geposted Sun 23 Sep 18 @ 8:20 am
You should select the ASIO driver instead of the WASAPI driver then.
geposted Sun 23 Sep 18 @ 8:32 am
Thanks, I'll give it try
geposted Sun 23 Sep 18 @ 8:33 am
Changed to Asio for master and headphones and appears to be working now. Thanks for all your help, much appreciated.
geposted Sun 23 Sep 18 @ 9:12 am
