Topic: Deck B Starts To Play Backwards
I have noticed that Deck B (Red) sometimes plays backwards and it cannot be reset in the program. Whilst using Denon MC6000 MKII all the other decks are fine and can use this as a work around with the only way to reset is to shut down the program and open again. Version running 8.3 b4537.
geposted Sun 23 Sep 18 @ 11:03 am
It's a feature that you somehow enable
To make sure you can get out of it, simply map a keyboard key to REVERSE - then you can always press that key to shift the deck back to normal
Any chance your "CENSOR" button gets stuck / malfunctioning ?
