I started by going to the manual and following the instructions here; http://www.virtualdj.com/manuals/virtualdj/editors/videoeditor.html . I downloaded the lyrics and saved them BUT now I can not find the file that I saved in order to play it. It is nowhere that I can find in the searchable database.
geposted Tue 25 Sep 18 @ 5:34 pm
EDIT:{ A ".vdjedit" } file is supposed to download into the same location as the audio file, and with the same name.
Old school... an LRC file would create. The new format allows for video controls that make the text look more like CDG files. Pretty cool...
geposted Tue 25 Sep 18 @ 6:03 pm
Thank you for your response. Forgive me here for making sure I understand, if the original audio file is saved in D:Drive subfolder / music then the corresponding file should be saved right there with it, right?
If that is the case then it is not saving and I am not sure what I am doing wrong here.
Or is it possibly saving to a folder associated only with VirtualDJ?
geposted Tue 25 Sep 18 @ 6:47 pm
Oh wow! I don't know what changed but now its working. I found them! thanks for the help.
geposted Tue 25 Sep 18 @ 7:35 pm
