Forum: Video Discussion
Topic: Having nothing to do with DJing......
Anyone know how to stream MP4s to a tv with a flash drive? I create alot of advertising for a local charity club and would like to stream them on one of the TVs.
geposted Wed 26 Sep 18 @ 9:40 pm
Stream them from where, your house to...……..?
geposted Thu 27 Sep 18 @ 7:25 pm
No AMAN, I thought from a flash drive. But I'm starting to figure out you need a hardware component to sit between the flashdrive and the TV.
geposted Thu 27 Sep 18 @ 7:54 pm
I think he wants to stick the flash drive into a USB slot on the TV and have it play the video files.
Depends on the TV of course, which he's not given any details on.
geposted Thu 27 Sep 18 @ 7:56 pm
a roku can do that
make sure the one you get has a USB port most of the cheap ones do not https://www.roku.com/products/roku-ultra
then you get it set up at home and install the app for playing media off usb drives
i have 3 roku 3 at home use them to do this ll the time :-)
geposted Thu 27 Sep 18 @ 8:18 pm
Hey Wicked, thanks for the idea, it sparked a few thoughts. What I have found is it takes hardware called Digital Signage Display Adapter, that you can feed with a stick or external hard drive. These things loop, and that's a necessity. Reliable ones run above
$200.
geposted Fri 28 Sep 18 @ 10:53 pm
ok sorry i didn't realize you needed it to loop
but i will say the roku i have has a repeat all and shuffle feature but no loop
geposted Fri 28 Sep 18 @ 11:08 pm
