Forum: VirtualDJ Plugins
Topic: Script for checking Loops and Loop Rolls
I'm looking for a way to check any current loop or loop roll.
In particular I want to know the length of the current loop or loop roll as well as whether they are active or not.
So far I can get all I need for loops with
deck 1 get_loop_out_time
which will give me 0 if the current loop is inactive and >0 if active.
I can also check the loop beat length with
deck 1 get_loop
As an aside I also tried
deck 1 get_active_loop
which gave me 1,2,4 for 1,2,4 beat length loops respectively when active and 0 when inactive but for <1 beat loops it did not work.
I got 1 for 1/2 beat loop when active and 0 when inactive but for <1/2 beat loops I got 0 for either active or inactive.
I'm not sure if that is just a bug with get_active_loop or whether it's doing the correct thing and I have misunderstood its purpose.
The main issue I'm having is getting loop roll info.
I can check for active loop roll with
deck 1 loop_roll_mode
this produces 1 when active and 0 when inactive.
I haven't been able to check the current active loop roll length.
I've tried
deck 1 loop_roll
but this doesn't produce anything.
Does anyone know if it's possible to get the beat length of the current active loop roll for a deck?
Thanks,
Ash
geposted Tue 02 Oct 18 @ 2:37 am
1) For loops you can just query the deck:
deck 1 loop ?
It will return true/false
2) For rolls you need to query all possible values:
deck 1 loop_roll 0.0125 ? on : deck 1 loop_roll 0.025 ? on : deck 1 loop_roll 0.5 ? on : deck 1 loop_roll 0.75 ? on : deck 1 loop_roll 1 ? on : deck 1 loop_roll 2 ? on : deck 1 loop_roll 4 ? on : off
Now, you can combine all these to a single query:
deck 1 loop ? on : deck 1 loop_roll 0.0125 ? on : deck 1 loop_roll 0.025 ? on : deck 1 loop_roll 0.5 ? on : deck 1 loop_roll 0.75 ? on : deck 1 loop_roll 1 ? on : deck 1 loop_roll 2 ? on : deck 1 loop_roll 4 ? on : off
This query will turn true (on) if a loop or loop roll is active, false (off) otherwise
You could also query if the loop roll effect is active
Thanks very much.
I've got it working with:
"deck 1 loop_roll 0.03125 ? set '%deckRoll' 0.03125 : deck 1 loop_roll 0.0625 ? set '%deckRoll' 0.0625 : deck 1 loop_roll 0.125 ? set '%deckRoll' 0.125 : deck 1 loop_roll 0.25 ? set '%deckRoll' 0.25 : deck 1 loop_roll 0.5 ? set '%deckRoll' 0.5 : deck 1 loop_roll 0.75 ?  set '%deckRoll' 0.75 : deck 1 loop_roll 1 ? set '%deckRoll' 1 : deck 1 loop_roll 2 ? set '%deckRoll' 2 : deck 1 loop_roll 4 ? set '%deckRoll' 4 : set '%deckRoll' 0"
and then querying the var for beat length of the roll:
deck 1 get_var %deckRoll
It's a pity there doesn't appear to be a quicker way of querying the beat length of the roll - or maybe I just haven't found it yet.
Cheers.
