While most FX are best set to post fader, the noise effect is an exception, it's better as a pre fader, so the 'noise' can be cut in and out, it's also easier to cut the sound entirely after a build up than returning the knob to the centre position. This is how the noise effect works on DJMs and with Rekordbox, it's pre fader, while other effects like space and dub echo are post fader.
Would it be possible to implement this change? Or taking it a step further, have a feature that allows the user to decide whether a particular effect is pre or post fader?
geposted Tue 02 Oct 18 @ 12:49 pm
I thought this was already implemented? isn't in options/effects/fxprocessing/ post effect on/off or pre effect on/off (something like that)
geposted Tue 02 Oct 18 @ 1:25 pm
Sorry, I didn't read your post correctly
geposted Tue 02 Oct 18 @ 1:27 pm
