Forum: Addons
Topic: Halloween Sound FX
geposted Wed 10 Oct 18 @ 6:07 pm
Brilliant work. Thank you for this
The installer for Windows (Win8) does not seem to work for me! Mac installer works fine!
Did you run the installer? Works here..
It basically just extracts a zip to the sampler folder
I don't believe I downloaded a zip file!
When I click on the downloaded file it asks me what program I would like to use to open it!
This is what I downloaded. When I click it it does nothing!
install_halloweensoundfx
Make sure the file name has .exe on the end.
It's that simple!
Will try that now!
THANK YOU SIR! YOU ARE A TRUE GENTLEMAN! IT WORKS PERFECTLY!!!
Thanks
