Discussion about Stanton DJC-4 By Pdrote
geposted Mon 05 Nov 18 @ 2:54 pm
This mapping modify fx function in stanton DJC.4 and remove video controls by other functions
-Fx- modified to match the skin (shift+knobb second parameter)
-Browser knobb- modified to also control the different panels
-Video knobb- modified for control of sandbox, prelisten, prelisten posicion, zoom wave.
-Smart fade/xfader link- modified for activate auxiliar line in deck 3/4
-Sampler+shift- play,stutter
-led sync butons- mark BPM in real tieme
geposted Tue 06 Nov 18 @ 1:36 pm
V 1.2
-Fixed some bugs
-more functions
-Fixed some bugs
-more functions
geposted Thu 08 Nov 18 @ 10:43 am
New version 2.0
-Graphic improvement
-fixed some bugs
-General improvement
The best version is still to come.
-fixed some bugs
geposted Fri 16 Nov 18 @ 4:33 pm
Mapping Stanton djc4 without video controls for use with the skin:
https://www.virtualdj.com/plugins/index.html?addonid=80934
Mapping Stanton djc4 with video controls for use with the skin:
https://www.virtualdj.com/plugins/index.html?addonid=80935
geposted Fri 16 Nov 18 @ 6:17 pm
Hi, I would appreciate it if some moderator deleted the first message.
They removed the link but not the message and can confuse whoever reads it.
Sorry for my english.
geposted Mon 19 Nov 18 @ 1:46 am
New version 3.0
-New panel minimalist design
-Cleaner and softer graphics
-New options
-Troubleshooting and minor changes
For the control of the wave zoom and alternate wave view in new panel, new version 1.3 of the mapping without video is necessary
Soon a new version will be available with more options and improvements. Possibility of working with pads ;-)
-New options
geposted Mon 26 Nov 18 @ 5:42 pm
NEW VERSION 4.0
-New options and inprovements
-Possibility of using the pads function
-Fixed bugs
For this skin version it is necessary to download the latest versions of the mapping for the controller stanton djc-4
Mapping djc-4 without video controls:
Mapping djc-4 with video controls:
-Fixed bugs
geposted Fri 07 Dec 18 @ 5:18 pm
hello buddy need help download this skin can you help?
geposted Fri 30 Aug 19 @ 2:32 pm
This skin is for licensed users. Buy a license and you can download it.
geposted Fri 30 Aug 19 @ 2:44 pm
yes bro I am a licensee but this does not happen
geposted Sun 01 Sep 19 @ 5:33 pm
Then you need to log in with the username and password you used when you bought the software.
Right now you're showing as a "No license user".
geposted Sun 01 Sep 19 @ 7:54 pm
HOLA, DE QUE OTRA FORMA SE PUEDE BAJAR O ME LO PUEDEN ENVIAR POR MAIL, YA QUE DE VDJ ME TIRA ERROR AL DESCARGAR EL SKIN SALUDOS
geposted Sun 18 Sep 22 @ 9:49 pm
Hey, this is a great skin vor DJC-4 thanks.
You have a few mistakes though.
In many placed you have "seck" instead of "deck" - it is only a tooltip, but it is there.
Also, I found icons that look like they shouldn't be there, maybe they are labels that are showing, I am not certain
There are other things, but I would like to be sure you are still improving this skin before I keep going.
Thanks
Thanks
geposted Mon 12 May 25 @ 12:28 am
You're critiquing a 7 year old skin, be realistic.
geposted Mon 12 May 25 @ 12:51 am
