Discussion about Mapping for stanton djc-4 with video
geposted Fri 16 Nov 18 @ 4:13 pm
This mapping modify fx function in stanton DJC.4 and others functions
-Fx- modified to match the skin stanton djc.4 By P.drote (shift+knobb second parameter)
-Browser knobb- modified to also control the different panels
-Shift+sampler - play stutter
-Sync butons led- mark BPM in real time
-Shift+load- unload
-Cue/play butons- modified to obey the configuration of Virtualdj (play options)
-Shift+load- unload
geposted Fri 16 Nov 18 @ 4:15 pm
Download the skin stanton djc.4 By P.drote
https://www.virtualdj.com/plugins/index.html?addonid=80861
Download mapping without video controls
https://www.virtualdj.com/plugins/index.html?addonid=80934
geposted Fri 16 Nov 18 @ 4:21 pm
Update is approved. Please next time, upload just the xml file. There is no need to zip the file.
geposted Fri 07 Dec 18 @ 3:56 pm
NEW MAPPING VERSION WITH VIDEO CONTROLS V2.0
This mapping version is for the skin STANTON DJC-4 By Pdrote V4.0 or above, some controls not function in older versions:
Complete list of changes:
-(FX) Modified to match the skin, (shift+Knobb) second parameter.
-(BROWSER KNOBB) Modified for control the different skin designs and better browser control. (shift+rotate) move in folders list, (shift+press, in folder list) open-close folders, (shift+press, in tracklist or sideview) change the control between the tracklist or the sideview, (rotate) move in track list or sideview, (press) change the different skin designs.
-(SHIFT+A-C LOAD BUTTON) In tracklist: add track to sidelist. In sideview: clear sidelist.
-(SHIFT+B-D LOAD BUTTON) In tracklist: add track to automix. In sideview: clear automix.
-(SYNC BUTTON LED) Mark BPM in real time.
-(SHIFT+SAMPLER VOLUME) Control BOOTH VOLUME
-(CUE AND SAMPLER BUTTONS) 1-8 pads when pads mode is selected in the skin
-(SHIFT+LOOP HALF/LOOP DOUBLE BUTTONS) In default buttons mode: previous sampler bank/next sampler bank. In pads mode: previous pads page/next pads page.
-(SHIFT+SCRATCH “VINYL”) The smart scratch function has been replaced by slip mode.
The version without video controls also available:
geposted Fri 07 Dec 18 @ 4:59 pm
OK, thanks
geposted Fri 07 Dec 18 @ 6:14 pm
