Discussion about Loop Out
geposted Thu 22 Nov 18 @ 2:57 pm
why is loop out effect not working proper like before
geposted Sun 02 Feb 20 @ 10:25 pm
Yeah I'm also having a problem with loop out after updating
geposted Sun 23 May 21 @ 5:12 pm
check the gui, everything works as expected here.
geposted Sun 23 May 21 @ 5:30 pm
Its working fine id just like to know what mode parameter does. using mac btw
geposted Tue 25 May 21 @ 6:09 pm
just some coloring or type of loop out ..
Can choose between fade, filter, step, no fade etc..
Just play around with it, and see what you like better
geposted Tue 25 May 21 @ 7:10 pm
Hi and thanks for this great effect.
I have 2 question please:
1°) What does the third parameter do please ? (I tried to change it but did not see any changes form 0 to 100%)
2°) In script mode, I understood that length is set in first paramater, but as it is in percentage, how to make it match with beat counting please ?
Thanks in advance for your help and have a nice day ;-)
geposted Wed 18 Oct 23 @ 11:18 am
1 for fade types hp & lp it's resonance of the filter
2 see the fx gui, all dials are valued between 0.0 & 1.0, this case there are 8 values that can be picked by the dial so they're all 0.125 apart.
geposted Wed 18 Oct 23 @ 12:09 pm
Great, that's all I need, many thanks for your help 👍
geposted Wed 18 Oct 23 @ 12:33 pm
