on the MCX8000 latest firmware, is possible to enlarge the waveform on the screen of controller??
pic 1 show vdj waveform, while pic2 show usb mp3 waveform
is really better pic2 wave.. how can i do?
geposted Sun 25 Nov 18 @ 1:28 am
If by enlarge you mean the height of the waves, then it's up to the gain value, same as in the main screen skin waves. When you took the above pic with VDJ, did you have gain at 50% ?
geposted Sun 25 Nov 18 @ 12:07 pm
thanks you djdad for your super fast answer.. i try this evening.. and it runs.. good.. i solved the problem.. but i have another problem.. probably it's a bug.. where can i say to the devolepers?
the problem is the script: "browser_geniusdj".that doesn't work..
i assign the script to a key on my keyboard.. but it doesn't run!
geposted Sat 01 Dec 18 @ 11:00 pm
