Topic: Weird Issue
So the other day I was practicing on my Denon 3700’s in midi mode.
Well I had one deck loaded and playing and loaded the other deck and hit play.
The deck wouldn’t start playing until the track was fully loaded, that’s my issue.
It would happen randomly but enough to irritate me because I couldn’t exactly quick mix.
All my tracks have already been analyzed and most have cue points set. They were all MP4’s and there’s just no rhyme or reason to it.
I’ll try to capture it on video tonight. Anything I should look for??
This is using the newest public build on a MacBook Pro.....
geposted Wed 09 Jan 19 @ 8:42 pm
Anyone run in to this problem??
Did it happen to both decks ?
Yes it does
Hmm...... anyone from the team care to chime in??
Ok I guess I just have to deal with this all weekend.
Thanks for the insight, top notch.
The deck didn't move either, or there was just no audio?
You had to press play again after the track was loaded, or it started automatically?
No audio played, I pressed play on the deck and I could see the play button lit up like it’s supposed to do when the track plays but the deck nor the audio played.
Once the track was fully loaded then audio and the deck both started.
Did you try using the previous build?
I think there was an issue with refreshing waveforms on mac, perhaps it's also affecting audio in your case.
I never knew about that issue but I’ll drop down a build and see what happens.
Thanks for the info.....
