Topic: Auto Connect BS
Greetings...
Maybe someone can help with this.
My search no longer finds songs in my library - instead it requests that I connect and then searches the online database... I never set this up, it just started. I assume it was snuck into an update or something.
Anybody know how I turn it off?
Thanks
geposted Fri 11 Jan 19 @ 2:05 am
Ok, well something else is up...
When I turn on my DDJ-SB2, I get a dialog box that says I do not have permission to use this controller. My license is for this controller. Need to uninstall and start over?
geposted Fri 11 Jan 19 @ 3:13 am
login to the software
geposted Fri 11 Jan 19 @ 3:21 am
Thanks... that takes care of the DDJ issue... duh - makes sense, much appreciated.
geposted Sat 19 Jan 19 @ 4:12 am
