Hi ! Thx for Your wonderful product. Here is my remark. Assining an effect player ( drums for instance ) to player nr 4, this player's output is depending of the horizontal cursor ( mixing left and right assingments ). The reasult is that I can't keep player 4's output active while leading player 1 to the output via the mixing slider. I wish I could select a player (at least nr4) to both left AND right from the slider.
Thank You for Your kind attention.
geposted Tue 22 Jan 19 @ 10:55 am
You can disable the assignment of deck 4 to any side of the crossfader.
geposted Tue 22 Jan 19 @ 11:03 am
THX a lot ! Sorry, I finally discovered that the selection is not needed. In this case, signal goes trough the mixing console but Not trough the left-right slider. You've made an outstanding machine !!
geposted Tue 22 Jan 19 @ 11:45 am
