Hi, repeatly i have troubles when compiling new lists in the browserlist of automix.
All works fine, untill the list is full.
When you then want to add more tracks, at the bottom of the list...it seems to be a bit difficult.
Or your add the tracks not at the bottom of the list, but as forelast.
Or when you do want to drag the song a bit further you end very quick at the buttons beneath the browserlist: sitelist or sampler.
Also, to get at the bottom of the automixlist, you have to drag the browserblockslider (at the right of the window) to the bottom, 'each time' before you add a track, which consumes a lot of time.
Is there a possibility, when adding a track at the bottom the list , it shifts automatically upwards?
geposted Sat 26 Jan 19 @ 5:28 pm
To get around this I mapped a button. A scroll wheel helps when dragging and dropping as well
geposted Sat 26 Jan 19 @ 6:01 pm
