Topic: Tracks Automatically Starting
I ran into a problem today where after I opened the program, the track of the last opened crate automatically loaded onto the A Deck and started playing right away. Has anyone ran into this problem before?
geposted Sat 02 Feb 19 @ 8:45 pm
did u hit any keys on the keyboard by mistake?
geposted Sat 02 Feb 19 @ 9:08 pm
ope, tired starting the program with and without a controller and it does it every time.
geposted Sat 02 Feb 19 @ 10:36 pm
PhilWPRO InfinityMember since 2011
Do you have a custom keyboard mapping? ONINIT defined?
geposted Sun 03 Feb 19 @ 4:11 am
I do not have any custom mapping set. It worked normally until I downloaded the last update V8.3 b4742
geposted Sun 03 Feb 19 @ 2:42 pm
If you think that's what caused it, go back to the previous build and see if the problem goes away.
geposted Sun 03 Feb 19 @ 3:20 pm
Yup, just went back and installed build 4720 and no longer have the issue. Thanks for the idea. But that's annoying the software is doing that.
geposted Fri 08 Feb 19 @ 6:49 pm
Sounds like a gremlin. No idea why that would happen at all.
geposted Fri 08 Feb 19 @ 7:36 pm
