Topic: Ddj 1000 mapping question
I wanted to reassign some of the buttons on the controller. It looks like deck 1 and 2 are controlled by the same mapping. Is there a way to segragate them? I.e. make the 'view' button on deck 1 behave differently than on deck 2? How would I differentiate the button in the mapping section?
Thanks
geposted Fri 08 Feb 19 @ 9:19 pm
action_deck 1 ? mapping for deck 1 : mapping for deck 2
geposted Fri 08 Feb 19 @ 9:28 pm
Thanks loco
I did the below script, but the playlist_add is happening for both buttons. Am I doing something incorrect?
action_deck 1 ? playlist_add : sidelist_add
geposted Fri 08 Feb 19 @ 9:42 pm
what buttons are you using?
try
device_side 1 ? mapping for deck 1 : mapping for deck 2
geposted Fri 08 Feb 19 @ 10:28 pm
Was trying it using the VIEW and VIEW_LONG buttons. Tried device_side, but no luck.
geposted Sat 09 Feb 19 @ 12:17 am
Update: I tried the action (action_deck 1 ? playlist_add : sidelist_add) on the browse knob when pushed, and it worked as expected. Adding track to automix playlist when pushing the deck 1 browse knob and sidelist playlist when pushing the deck 2 knob.
It seems the issue is related to me using the 'View' button for this script. Any thoughts as to why that might be?
geposted Sun 10 Feb 19 @ 11:09 pm
Ok final shot try
device_side "left" ? script1 : script2
geposted Sun 10 Feb 19 @ 11:43 pm
From looking at Midi Table device_side "left" is my best guess, If I had access to the def file I could be certain (and much quicker for you)
But atomix keep tight control of def files to prevent them being leaked, some hardware makers are decent and provide midi tables but it's still a lot of work to write a def file, some hardware isn't as nice and staff like phantom & djdad have to do a lot to get stuff working.
geposted Mon 11 Feb 19 @ 12:38 am
Or.... you do something like this:
holding 1000ms ? sidelist_add : playlist_add
geposted Mon 11 Feb 19 @ 9:44 am
On some devices buttons like "VIEW" send the same MIDI message from both sides when pressed. In other words they behave as one button with two instances. Therefore it's not possible for VirtualDJ to tell the "deck" or "side" of the controller the button was pressed. That's why your "VIEW" button can't be mapped like that, but other buttons can.
If I remember correctly "BACK" button falls in the same category as well
geposted Mon 11 Feb 19 @ 12:40 pm
I see now, b-2 & b-3, sorry I read the table wrong.
geposted Mon 11 Feb 19 @ 1:01 pm
It's quite common for Pioneer to bind these buttons on all units that have dual browser control sections (like DDJ-SZ, DDJ-SZ2, DDJ-RZ, DDJ-RZX e.t.c.)
The browser knob also falls in the same rule, with the exception of "push" action on some units when it's used to LOAD a song (like DDJ-SZ for instance)
geposted Mon 11 Feb 19 @ 1:28 pm
Thanks for the additional color. I ended up splitting them up by a press or a long press on the view button.
In the long run that's probably a better solution since I can browse the library from either side.
Thanks again everyone!
geposted Wed 13 Feb 19 @ 12:16 am
gmediaPRO InfinityMember since 2007
I am trying to trigger some lighting controls in SoundSwitch using the pads on the DDJ-1000. I don't know if this is the best place for this or not? Any ideas on how to do this? The SS software is looking for me to press a button on any connected midi controller to map.
Chris
geposted Sat 29 Jun 19 @ 12:44 pm
