I need help. How to configure VMS5 with Virtual DJ? I want to connect speakers and headphones under the controller. The speakers are resistant to the master and headphones to the headphone jack.
geposted Sun 10 Feb 19 @ 1:59 pm
Follow this
http://www.virtualdj.com/manuals/hardware/americanaudio/vms5/installation.html
If you struggle post a screen shot of your audioConfig
geposted Sun 10 Feb 19 @ 2:05 pm
I set it this way but the sound on the headphones does not work. I also used the setting as in the link, but then the cue only works on deck 1
https://drive.google.com/file/d/1TlRlM9qL-d4CFXc_Jtpp6LeVSiX0GnyH/view?usp=drivesdk
geposted Sun 10 Feb 19 @ 9:04 pm
try the external mixer setting and please confirm
The manual wrote :
Setup: Set the front switcher to 8out position. Connect your amplified speakers or your amplifier to the Master (RCA or XLR) outputs at the rear side and power on the unit from the back switcher. Connect your Headphones at the front side and make sure all MIDILOGS switchers at the front are on USB position.
geposted Sun 10 Feb 19 @ 9:13 pm
The first configuration of the program with four deck is fine. The problem was solved after changing the CF A and CF B settings on the front panel. Everything is working, thank you for your help.
geposted Mon 11 Feb 19 @ 9:59 pm
