Topic: iTunes Playlist
How do you get the iTunes music to play in Virtual DJ? The new file format is MP4 and just will not import in.
geposted Thu 14 Feb 19 @ 1:36 pm
If you mean Apple Music (the rental service), then no you cannot use it in VDJ or for that matter anywhere else other than iTunes - due to the simple fact that it's copy protected for a reason. It's for personal use only, and it's rented. It doesn't belong to you.
If you want to be able to play music anywhere on anything, then you need to buy it, not rent it.
