The audio from Ableton doesn't sync with vdj's BPM, vdj deck A is 125 BPM but Ableton's one is 176 and can't sync? Any Help?
geposted Tue 19 Feb 19 @ 11:38 pm
Try using Ableton Link instead.
geposted Wed 20 Feb 19 @ 5:33 pm
ReWire is like a "wire" or "sound cable" into other application. Where there is a host application, that gets the sound.
Its no sync over the protocol, but rather the host application can sync to the audio stream coming from the client/slave.
https://www.virtualdj.com/manuals/virtualdj/settings/audiosetup/rewire.html
So in this regards, VirtualDJ can sync to the sound coming from Ableton (or any other ReWire source), but Ableton (client/slave) can not sync to the host.
If you want a two-way sync, you can also engage the Ableton Link feature in VirtualDJ, that is made for the purpose of syncing over network (both ways).
https://www.virtualdj.com/wiki/abletonlink.html
geposted Wed 20 Feb 19 @ 7:13 pm
The audio from ableton sounds bad when I rewire into vdj. It's sounds like noise or distoriton or something but I don't know how to fix it
geposted Tue 02 Feb 21 @ 1:23 pm
