please make another duplicate remover for main database im running out of space and i know i have doubles
geposted Fri 22 Feb 19 @ 10:15 pm
You can add a filter-folder with "duplicates" and Scope on Database.
Did you try this?
Did you try this?
geposted Fri 22 Feb 19 @ 11:32 pm
and just for fun if you wanna easily verify videos/karaokes are exactly visually the same add a "Compare" custom button :
"toggle & holding ? deck Left unload & deck right unload : crossfader 50% & play ? deck Left pause_stop & deck right pause_stop : deck Left load & deck Left pitch 100% & browser_scroll +1 & deck right load & browser_scroll -1 & deck left play & deck left pitch 100% & deck right play_sync_onbeat & deck right pitch 100% & deck right sync"
point the top one and click to load and play, click again to pause/play , hold to unload
note you can't assume the audio/video resolution are the same , use tag editor for that
geposted Fri 22 Feb 19 @ 11:58 pm
Man Thanks for sharing this script!!
geposted Sat 23 Feb 19 @ 1:03 am
