When adding POI's and pressing the "..." macro button would it be possible to allow 'user action parameters' to be added/saved for future recall? It might help if I explain step by step.
When using POI's to send OS2L DMX commands:
I open POI editor on a track
I click 'New' for a new point
I select 'Point Type' = Action
And I press the '...' to open Macro in the 'Macro action' section
Under Category I select 'controllers'
Under Action I select ''os2l_button', which pre fills the action with the text 'os2l_button'
Next we have to enter some parameters for the OS2L action.
It's these parameters that I would like to be able to be saved into user editable fields so the parameters could be recalled negating the need to remember and type them in each time.
For example to control one of my fixtures I send:
os2l_button2l_button "windmill" "on"
and later add another POI
os2l_button2l_button "windmill" "off"
With 50+ different DMX fixtures and 100+ scenes remembering all the different parameters for the actions is difficult. So if there could be a third areas in the Macro dialog that allowed for user parameters to be entered / deleted and then picked it would make the entering of OS2L POI's much easier and faster.
Possible?
Possible?
geposted Mon 04 Mar 19 @ 1:46 pm
