Forum: Addons
Topic: Jog-Grid
Discussion about Jog-Grid
Re-modified skin based on VirtualDJ's original 4 deck skin and mod by TeslaX
geposted Thu 07 Mar 19 @ 8:05 pm
bro can you make a way where you can change the skin color especially daylight skin (white). Thanks awesome skin
the time
The skin is just a modification of the Atomix Productions/VirtualDJ original 4-deck skin.
Modified by TeslaX and Re-modified by me (fixes, improvements, clean up etc)
Will fix clock for mac, the current mod has a few minor glitches still. And look into making a daylight version as well
I got a few requests. Can you add a key change drop down mode like on the two deck mode for the four deck? Can you put the option to have the two deck mode? Can you make the pitch slider way lighter? and lastly Can you put a pitch reset button by the pitch slider like on the original? Thanks. I love this skin so far!!!!!
Hi
I really like this skin but was wondering will there be a 2 deck option?
I like the skin myself. Would like to see a 2 deck option.
I've been messing around with the 2 deck version over the weekend (changing things to my preferences).
Removed the rhythmwave display. Moved the VDJ logo back up to its normal place (moved the clock to accomodate).
Removed the beat keeper and phase indicators, and put the skin name there instead. Moved the pitch % display to the top of the pitch fader, where it's clearer/larger.
Changed DEL text to EJECT. Removed all the unneccessary duplicated info from the jog wheels (it's already in the deck displays).
Changed the deck BPM display to reflect pitch changes. Centred the sandbox text (it was hanging over the button) and removed the logo.
Added a 'colour choices' menu to the VDJ logo.
I still have more mods to do, but it's going OK so far.
Hello, are there any news on that?
I could be wrong, but I honestly don't think we'll see Mister Skinner here again.
Kool I like what you are doing with this skin can you add a choice of 2 decks layout as well also will you be sharing your version.? PS I like your choice of colors.!!!
What Happened to Mr. Skinner.? just wondering.!!!
great job on the skin, ive been looking all over for a 4 deck option with key match, as im still learning, anyway you could accommodate that? I would greatly appreciate it! I been using your skin for the past week now and that is the only thing I miss from the default 2 deck, either way you did a steller job!!
Any word on a 2 deck version?
I'm unable to download skins in app. It says download failed with and without VPN enabled. I upgraded to the latest VDJ 2025 as well and same result. Is it still possible to download/install these manually?
No, not from the website
But I think you should just wait for a bit. I think there is currently a general download issue
EDIT: I think it's working again now
