hi all
i have an issue with ddj sz2 as i tryed to make it work with virtual dj 8 but faces an issue with the headphones
as there is no sound coming from them
i have ddj sz and ddj sz2 and i wonder if i can keep both the drivers on the same system or it will get conflict
and lately virtual dj 8 while playing and mixing normally it would freeze for 10 seconds and then comes back and sometimes when i load a song it takes 10 to 15 seconds to fully load
don't know why it happens
any help will be appreciated
regards
regards
geposted Sun 10 Mar 19 @ 2:51 pm
regards
regards
That might be due to the external hard drive going to sleep.
And takes some time to wake up again.
Most externals come with a config tool. Check if you can increase the time before the hdd goes to sleep.
If you don't have such tool or you can not change the time there are other tools like this one which will prevent the hdd going to sleep.
https://archive.codeplex.com/?p=nosleephd
geposted Mon 11 Mar 19 @ 9:01 am
