que tal compañeros, tengo un problema para instalar la ddj rb, ya instale los driver mas recientes y no me da el audio en los audífonos también hice algunas configuraciones que me recomendaron y nada aun.
si alguien ya tubo este problema espero y me pase los tips. saludos
geposted Mon 11 Mar 19 @ 8:10 pm
geposted Mon 11 Mar 19 @ 9:03 pm
Please write in English or use the Spanish Forum.
In your 2nd pic i see "Error" on the right side for line 2 (Headphones). Wasn't Pioneer ASIO driver installed properly ?
Also, no matter if you use WASAPI or ASIO driver (BTW, prefer to use one or the other, not both in the same Audio Setup), Headphones should be routed to Channels 3,4 , not 1,2 which is for Master.
Click on the "PIONEER DDJ-RB" button you see at the middle-top section of Audio setup, for VDJ to auto-create the correct/default audio configuration for you.
geposted Tue 12 Mar 19 @ 3:04 pm
I already did all that and nothing, I installed it on another computer and it marks the same error and it tells me that the driver's signature is not recognized
geposted Tue 12 Mar 19 @ 4:20 pm
