I would like to have a couple off buttons to use as On and Off for videos.
When I hit the button once the video for ex. desk1 goes black and the second hit, the video on desk1 shows again.
Can this be done ?
Can this be done ?
geposted Fri 22 Mar 19 @ 5:17 pm
Don't think you can disable video per deck.
You can create a custom button to switch the video output on and off though just by using the command video
geposted Fri 22 Mar 19 @ 5:20 pm
You could set up Slideshow or another video plugin on each deck and use it with a black picture for example.
Then activate it whenever you want to hide the video on that deck.
geposted Fri 22 Mar 19 @ 5:25 pm
deck 1 leftvideo ? deck 3 leftvideo : deck 3 leftvideo ? deck 1 leftvideo : deck 3 leftvideo
Won't this do it?
Won't this do it?
geposted Fri 22 Mar 19 @ 7:05 pm
Genius !
I will try this to get the function I want, for some cut mixing both video and audio..
The only problem is if I have video loaded on deck 3 and 4.. but I dont always mix videos with 4 channels :)
deck 1 eq_kill_high & eq_kill_low & eq_kill_mid & deck 1 leftvideo ? deck 3 leftvideo : deck 3 leftvideo ? deck 1 leftvideo : deck 3 leftvideo
geposted Fri 22 Mar 19 @ 7:22 pm
there is 'video_level' for that
video_level 0% ? video_level 100% : video_level 0%
geposted Fri 22 Mar 19 @ 7:24 pm
Didnt do it right ?
geposted Fri 22 Mar 19 @ 7:26 pm
Supplemental but
could be
deck 1 mute
could be
deck 1 mute
geposted Fri 22 Mar 19 @ 7:46 pm
Thank you for the help.
works like I wanted, on all channels
deck 1 mute & video_level 0% ? video_level 100% : video_level 0%
deck 2 mute & video_level 0% ? video_level 100% : video_level 0%
deck 3 mute & video_level 0% ? video_level 100% : video_level 0%
deck 4 mute & video_level 0% ? video_level 100% : video_level 0%
geposted Fri 22 Mar 19 @ 9:32 pm
If this is working as you need
"deck 1 mute & video_level 0% ? video_level 100% : video_level 0%"
it looks like you are using one button per deck. "deck x" is not needed in this case as the following "video_level" will apply to current deck when no "deck x" is specified for it. "mute" will act the same
"mute & video_level 0% ? video_level 100% : video_level 0%"
would be enough for the button on any deck
geposted Fri 22 Mar 19 @ 10:41 pm
Hey Nicotux, the point is to cut one channel @ the time.
Now I have just noticed a new problem when updating.
The video transition effect "Color Swap" is not working properly with this script.
I made a small video to show you, and I hope the dev. team will see this and have some answer later ;)
https://youtu.be/co5p-UDG1TI
geposted Sat 04 May 19 @ 2:25 pm
