Is there a way to adjust the curve of the channel faders? I need 0-100% volume between 50-100% of the fader position
geposted Fri 19 Apr 19 @ 1:16 pm
This is possible by using a crossfader
FROM VDJ8 DOC:
"crossfader_curve" : select the curve of the crossfader. enter a value to adjust the slope from a X curve (0%) to a inverted-U curve (100%).
You can also specify common curves by name ("smooth", "full", "scratch", "cut").
Or you can draw your own curve, using a syntax like 'crossfader_curve "0=[1,0]/0.5=[1,1]/1=[0,1]"'.
But for slider, verbs "fader_curve" and "levelfader_curve" exist
You'll have to experiment with "fader_curve" as this is not documented for that
FROM VDJ8 DOC:
"levelfader_curve" : select the curve of the level faders. 0% is a linear curve, 50% (default) is a quadratic curve, 100% is a cubic curve (Synonym for fader_curve)
https://www.virtualdj.com/wiki/VDJscript_verbs_v8..html
FROM VDJ8 DOC:
FROM VDJ8 DOC:
geposted Fri 19 Apr 19 @ 2:18 pm
param_add -0.5 & param_multiply 2 & level
geposted Fri 19 Apr 19 @ 2:51 pm
Thanks for the tips. I'm getting closer with
volume & levelfader_curve 100%
I've been playing with fader_curve. I'm guessing the decimal number is the volume, and [1,1] is the middle of the fader, or vice versa.
volume & fader_curve "0=[1,0]/0.5=[1,0]/1=[0,1]"
or
volume & fader_curve "0=[1,0]/0.0=[1,1]/1=[0,1]"
Like this locodog? Sounds right but often sticks at 0%
volume & param_add -0.5 & param_multiply 2 & level
or
geposted Fri 19 Apr 19 @ 6:00 pm
