Hi,
I've been trying to get tracks to show in list view on the tablet skin so I can try it out on my touchscreen laptop, but can't get list view to show at all.
So far I've tried:
- Setting touchScreenMode to 'No' in the options
- Setting gridView to 'No' in options
- Changing to touchscreenmode="false" in tablet.xml
- Removing the above line from the xml completely
- Starting the program with Windows set to tablet mode
- Making it show extra details (thought it might force it in list but just makes the boxes bigger)
Would love to try out the tablet skin but can't work with grid mode, any suggestions?
So far I've tried:
geposted Sun 21 Apr 19 @ 8:01 pm
          Just test:
take care touchScreenMode is set to "no"
modify touchscreenmode="no" in first line of the xml file
save
select the right skin i.e.: default (modified)
works fine
save
works fine
geposted Sun 21 Apr 19 @ 9:38 pm
          "select the right skin i.e.: default (modified)"
Thank you Nicotux, I was just using the toggle button at the top to switch between 2 decks and tablet and hadn't realised it had created a new category of skins called Default (edit).
geposted Sun 21 Apr 19 @ 10:09 pm
