Topic: Autogain / limiter
hejzanPRO InfinityMember since 2009
I have anylized everytrack and still alot of diffrent gain volym on diffrent tracks.
Each Channel often hits red and some Only 3 green thrue there same volym out .
Also when 2 powerful Songs plays at same time the master hits limiter
My friend use the same files as me and use Serato and has better sound then me.
When i Google this problem often says that VDJ autogain Good 99%.
Feels so wrong to use autogain + remember to manual set gain to each track.
geposted Sun 05 May 19 @ 9:22 am
Yes, 2 songs on top of each other can do that
That's why I usually set the zeroDB setting to -1dB or -3dB
That's because Serato cheat :)
They basically adds kind of what the Loudness button was like on old 90's stereos
They really shouldn't do that as default
- a DJ software should always send the audio out "flat", and let you add whatever you want later in the signal chain, or maybe as a master effect in the software
geposted Sun 05 May 19 @ 9:53 am
Dj-RFTDPRO InfinityMember since 2018
geposted Sun 05 May 19 @ 9:58 am
Why do you want to play 2 powerful songs at the same time without using eq/volume?
The volume would be 2x higher than during normal playback too, which I doubt you want.
If you do want to do this, you could set the zeroDb option to -3dB or -6dB to give you more headroom.
geposted Sun 05 May 19 @ 11:42 am
