I have gotten the broadcast URL and stream key, and entered both in VDJ.
However, when I attempt to begin the broadcast (after initiating video and music) and click "Start Broadcast", all I get is "Starting Broadcast". I checked my FB feed and home and there is no live video.
On the other hand, I can Livestream directly from my desktop camera without any problems.
It's probably something simple that I am missing.
Thanks.
Thanks.
geposted Sun 05 May 19 @ 8:44 pm
Unable to live stream at all.
geposted Mon 06 May 19 @ 1:14 am
Hello, same here.
geposted Wed 08 May 19 @ 12:07 pm
Facebook have changed something to do with rtmp & rtmps, I saw a post earlier by djdad saying the devs are aware and on top of it.
geposted Wed 08 May 19 @ 12:30 pm
Has this been fixed, i'm still having the same problems, it just stays at "starting broadcast..."
geposted Mon 03 Jun 19 @ 3:20 am
Having issues with the streaming on Facebook to. Why do some devs say it was resolved and some say its not? If resolved please provide a procedure to get the stream to go live
geposted Tue 11 Jun 19 @ 1:24 am
What build of VDJ are you running? Check the build history and make sure you’re running the one with the fix or later.
geposted Tue 11 Jun 19 @ 12:01 pm
It works fine - just tested it
Latest public build 5002
geposted Tue 11 Jun 19 @ 1:11 pm
What are your settings or what did you do to get it to work? I need assistance not confirmations. Thank you.
geposted Wed 12 Jun 19 @ 1:20 am
I am using the correct build the dev presented in another post 5002. I checked to get updated from older versions in the settings. I restarted the computer. So it was a clean start. Restarted the browser. Still nothing. On my FB live it allows me to go live with the camera just not the connect option. What do I do from here?
geposted Wed 12 Jun 19 @ 1:23 am
Is there a virtual DJ moderator besides "locodog" who can actually advise instead of closing out posts?
geposted Wed 12 Jun 19 @ 4:24 am
Thread was locked as a duplicate. Cross posting causes confusion.
I've just now started from scratch [adding the url and key into vdj] with 5002 and broadcast fine
geposted Wed 12 Jun 19 @ 4:57 am
I do it like this using build 5002 (latest public build):
geposted Wed 12 Jun 19 @ 7:53 am
