Topic: Ableton link not there - Page: 1
Hi, just been trying to set up ableton link to link VDJ8 pro (v8.3) to ableton, i looked in the extensions folder under effects but ableton link in nowhere to be found, did a search and comes back with nothing, all the 'other standard' effects appear in each decks drop down of effects, but not ableton link
help me please :-)
geposted Thu 09 May 19 @ 1:44 pm
I still see it on my setup
geposted Thu 09 May 19 @ 11:17 pm
well, yeah, this is the problem, i can see everyone screen shots and that they have it there, but i dont.
my understanding is its built into VDJ 8 so there isnt even a method to insert it like you would any other effect
cant understand why if it's part of the build why it doesnt appear ???? (or how i can make it appear)
geposted Fri 10 May 19 @ 7:30 am
by way of interest, what operating system you using, i'm on windows 10 and my screen looks slightly different from yours, i dont have the sub bar of audio FX under the effects, it via a drop down menu called category ?
geposted Fri 10 May 19 @ 7:33 am
What build of vdj do you have. You are searching inside vdj aren't you?
geposted Fri 10 May 19 @ 7:34 am
VDJ8 pro infinity (v8.3)
yep, i'm doing what i should be going to settings / extensions / audio FX
within there are some , such as eq10, sweep auto, eq30, loop out shrink loop etc.....but no ableton link
search doesnt find it either
if i look on a deck at the effects drop down, i have all the other standard effects, flanger , brake start, distortion etc etc...but again, no ableton link
geposted Fri 10 May 19 @ 10:00 am
It's included but not visible before you install it
I just re-tested, and this screenshot in on Win10 with the latest 32-bit public version of VDJ8.3/2018, which is build 4918
geposted Fri 10 May 19 @ 10:42 am
im on build b4514
how do you press the install button if it isnt visible ??
my understanding is you can see it in the audio fx extensions, you then click the 'Install' button to install it
but it's not there, how do i install if its not visible / there ?
geposted Fri 10 May 19 @ 12:52 pm
The current public build is 4919, so you need to update if you want to use Ableton link.
Also, it's easier if you use your pro account to login on the forum.
geposted Fri 10 May 19 @ 12:59 pm
Updated to latest version, yep that done the trick, thanks V.muchos
geposted Fri 10 May 19 @ 1:22 pm
The question is how do you use it? Iv spent all night trying to get sound from ableton live lite 10 into vjd2020
Iv read old post and downloaded all the extra things people say you need in these chat room. Asio4all driver some program called oxi somthing
(it's definitely not right but of top of my head its close too late too tired, was that bad I had to listen to Winston Churchills drunkkirk we will fight on the beach speach to give me strength continue until this un godly hour of 540am and retreating to bed mission failed)
So please can anyone help?
Me achieve my goals of spin house music and dropping notes from my akai mpk minin
And also be able to control clips from ableton live with a launch pad mini
With the sound coming through aux in vdj
geposted Wed 12 Feb 20 @ 5:47 am
See what I'm saying no one from vdj answering questions
geposted Wed 12 Feb 20 @ 6:42 pm
goodcolHome userMember since 2018
13 hours give them a chance, if you want concierge service then it costs a bit more than a basic subscription.
geposted Wed 12 Feb 20 @ 6:49 pm
geposted Wed 12 Feb 20 @ 6:56 pm
So vdj infinite pro won't do it?
geposted Thu 13 Feb 20 @ 7:10 am
And only a12 hours I'm a paying customer not a freeloader
geposted Thu 13 Feb 20 @ 7:11 am
Basically subscription wtf, may be I should have told my bank to paid with ripped with ripped up notes.
I got the subscription for one reason other then that I don't need pro.
And I was told I'd need a pro and its on ticket so. What's the score
geposted Thu 13 Feb 20 @ 7:15 am
Check wanna be vjd rep, trying to push what iv already got lol, don't talk unless you got answer to why aux isn't working while abelton live is acting as a slave.
Information on these chats are not the same as in the official manual.
With people saying to download extra programs
While the main vdj instructions on rewire section makes it sound like it's just selecting as simple as selecting audio drivers.
geposted Thu 13 Feb 20 @ 7:26 am
How does your audio setup look like? You should have a line input there with ableton rewire selected.
You don't need any other downloads for that.
geposted Thu 13 Feb 20 @ 10:32 am
Ableton Live is 64 bit only now, so you need to also run the 64 bit version of VDJ or Rewire won’t work. Also you cannot use MIDI controllers with Live when it’s slaved.
You could try Ableton’s Link system too...
geposted Thu 13 Feb 20 @ 12:50 pm
45%
