Topic: EQ 10
I am curious about a video from Virtual DJ tutor Klaus Mogensen about EQ10. i could not get the drop down with those presents profile. I tried deleting and reinstalling EQ with no luck.
geposted Fri 10 May 19 @ 2:24 am
DeeJay MAE wrote :
Hi, download this addon from the Development team, it only works for the 32-bit version:
https://virtualdj.com/plugins/?addonid=80773
Yes that's the one from the video
It's really included in the software, though not visible/available, but you can "get" it under extensions
Doesn't work on a Mac, I've tried for years. EQ10 will download, but, not the presets.
I just tried minutes ago with both methods above with no luck.
There are no default presets included with the internal one, but you should be able to save your own
Yes, you can save your own, but, Klaus suggested above that the presets in the OP's picture came with the download.
Maybe klaus could share the contents of eq10.dat as text. inside [nobbc][code][/code][/nobbc]
No configuration settings in sound effects folder.
A .dat file is created once you make and save a profile.
Oh, so mine are spill overs from the previous effect?
I didn't even know that - sorry :)
My EQ10.dat file looks like this:
19
0.464286,0.642856,0.67857,0.535714,0.464286,0.464286,0.5,0.5,0.642856,0.642856,Dance
0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,Flat
0.464286,0.535714,0.571428,0.607142,0.464286,0.464286,0.5,0.5,0.642856,0.642856,Rock
0.464286,0.5,0.571428,0.571428,0.464286,0.464286,0.5,0.5,0.642856,0.71428,Rap
0.357144,0.5,0.5,0.428572,0.5,0.5,0.571428,0.59375,0.503233,0.40625,Grunge
0.357144,0.5,0.5,0.428572,0.5,0.5,0.59375,0.5,0.59375,0.535714,Metal
0.28572,0.535714,0.642856,0.464286,0.464286,0.428572,0.5,0.5,0.67857,0.67857,Techno
0.464286,0.5,0.5,0.571428,0.571428,0.5,0.5,0.5,0.607142,0.607142,Country
0.5,0.5,0.5,0.607142,0.607142,0.607142,0.5,0.571428,0.642856,0.642856,Jazz
0.5,0.535714,0.571428,0.5,0.5,0.5,0.5,0.5,0.571428,0.571428,Acoustic
0.464286,0.5,0.535714,0.5,0.571428,0.5,0.5,0.5,0.571428,0.5,Folk
0.5,0.607142,0.607142,0.5,0.5,0.5,0.5,0.5,0.535714,0.535714,New Age
0.5,0.71428,0.607142,0.5,0.5,0.5,0.5,0.5,0.571428,0.571428,Classical
0.464286,0.5,0.571428,0.535714,0.5,0.5,0.5,0.5,0.464286,0.392858,Blues
0.428572,0.5,0.571428,0.535714,0.5,0.5,0.5,0.5,0.428572,0.32147,Oldies
0.464286,0.5,0.5,0.392858,0.5,0.607142,0.642856,0.5,0.607142,0.642856,Reggae
0.5,0.5,0.5,0.607142,0.642856,0.571428,0.67857,0.571428,0.5,0.5,Opera
0.464286,0.5,0.5,0.5,0.607142,0.607142,0.5,0.571428,0.642856,0.642856,Swing
0.428572,0.5,0.571428,0.535714,0.5,0.5,0.5,0.5,0.428572,0.32147,Speech
0.5,0.4375,0.5,0.5625,0.5625,0.428879,0.53125,0.53125,0.5625,0.5625,Mix
Nice one klaus, yeah that worked, edit eq10.dat [found in sound effects]
19
Can someone please tell me how I can use the above I have created a .dat file and put it in the same folder as the eq 10 plugin thank you
open the .dat with notepad, put the text in and save.
Can anyone enlighten me about the use of presets named after genres?
I mean, I'm sure a rock artist knows how he wants rock to sound, so he would already have mastered the song with the right amount of bass and treble.
Or should they be used in the opposite way? You choose the 'rock' preset to make it sound less like rock, so that it sounds more like your other music? :p
You must put the Dat File to
C:\Users\USER....... Your Name\Documents\VirtualDJ\Plugins\SoundEffect
Only than VDJ can found this File ;-)
I think historically the naming has come from domestic use, on hifi systems, for consumers.
I don't see the point of having presets for DJing use, as surely the only time a graphic EQ is (or should be) required is to compensate for room acoustics - and that would differ from venue to venue. IMO most places that a mobile DJ is likely to play wouldn't need any EQ at all anyway (assuming decent source equipment, so the DJ is not EQing to compensate for low quality music files, cheap mixer or speakers).
what is the directory for mac?
