Topic: Channel levels no longer showing
Hi, my channel levels on my mixer and on VDJ are no longer showing up? What am I doing wrong?
geposted Sat 11 May 19 @ 7:16 pm
You're not providing enough information.
What mixer are you using (make and model) - or are you actually using a controller?
What (exact including build) version of VDJ are you running? What skin are you using?
What are you audio config settings?
Are you using Mac or PC?
When you say "no longer", that implies it was working at some point before. When? What's changed since then?
If i recall correctly, there was a bug at some point where VU meters were not working, if sound card was set at 192Khz, but that was solved on the way. So, try to update to the latest available Build, and if still not working, further details will be needed.
Sorry, it’s a controller Pioneer DDJ-SB2, latest version of VDJ 8 using VDJ 7 skin. Using Windows laptop. Since an update a few months back the VU Meters don’t show at all and VDJ doesn't find the soundcard for the DDJ-SB2
Ah, so if VDJ is not using the SB2 audio interface, how are you outputting audio?
What "latest version" of VDJ 8? Pre-release? I asked you to provide the build number....
Have you tried reverting back to the build before the update "a few months ago"?
