When will VDJ 8 support the Pioneer DJM 450 Mixer
geposted Tue 14 May 19 @ 1:38 am
It's a standalone mixer, so you can use it quite happily with VDJ by using the "external mixer" config in VDJ (sending each VDJ deck to separate inputs of the mixer). Then you just mix as you would if there was no computer.
In other words, the mixer does not need to "control" the on-screen mixer in VDJ. You have a real mixer, the on-screen one is not required.
geposted Tue 14 May 19 @ 2:56 am
@djmidz We have some unfinished mapping files for you to try, but we could not reach you to your account's email (bounced). Check your PMs.
geposted Tue 14 May 19 @ 6:18 pm
