Four of the original sound effects "airhorn, siren, applause & explosion" just stopped working. I did not change anything or do any updates. Can someone tell me how to fix this??
geposted Wed 22 May 19 @ 2:26 pm
So, they re not in the AUDIO Sampler Bank, or cant get any sound from them ?
Do other audio samples work fine ?
In case you have accidentally removed them, you can go to VirtualDJ Settings->Extensions tab, select the "Sampler" category and "audio Effects" as sub-category, scroll down to find the "Audio FX " Sampler Pack, press Uninstall and then Install.
geposted Wed 22 May 19 @ 6:48 pm
New samples
geposted Tue 18 Jun 19 @ 10:47 am
