Topic: VirtualDJ8 and Stanton DCJ.4
nilaymkPRO InfinityMember since 2019
Hi all
I am thinking of buying a Stanton DJC.4. It comes with VDJ 7 LE. I was wondering if it is a free upgrade to VDG 8 LE?
p.s. VDJ site says that some manufacturers have tie ups in with VDJ 8 LE upgrade is free however doesn't say which controllers can avail this.
Any info greatly appreciated.
geposted Thu 23 May 19 @ 1:44 am
Yes, Stanton DJC-4 offers VirtualDJ 8 LE.
Users with old version 7 LE DJC4 serials will get both.
Users with new version 8 LE DJC4 serials will get only ver8 LE.
If you buy new from store, most likely it will come with new serial, but it could be a stock as well. You can see the available LE versions once you put your LE serial here.. http://www.virtualdj.com/le/
geposted Thu 23 May 19 @ 9:42 am
Thanks djdad. Thanks for the tip and info...really appreciate it.
I entered the keycode in virtualdj.com/le it gives me option to install version DJC4 7.4 and version DJC4 8.0.2048.
Is version 8.0.2048 then upgradable to latest build (i.e. 8.3) or do I only get the 8.0?
Cheers
Nilay
geposted Sat 25 May 19 @ 11:02 am
Latest 8.3
geposted Sat 25 May 19 @ 11:03 am
