It's been awhile since I dabbled with the features in VDJ. I do remember adding fx to one shot samples, however the fx would be applied globally effecting other one shot samples I didn't want fx applied to. Is this how it works in VDJ? I would like to be able to apply fx to one shot samples individually without VDJ automatically applying that fx to all the samples.
geposted Thu 30 May 19 @ 4:46 pm
Fx on the sampler effect all samples, to have solo fx on a sample you have to drag it to a deck.
geposted Thu 30 May 19 @ 5:02 pm
Thanks for helping, however that's not practical. Hope VDJ team looks into this and makes it possible in a future release.
geposted Thu 30 May 19 @ 9:40 pm
How is it not practical? Are you aware that VDJ can have up to 99 decks (so you can load samples and still have decks left for music)?
The default skin has a six deck option. There are other skins with more decks, even skins designed for loading samples to decks.
geposted Fri 31 May 19 @ 4:38 pm
Thanks for the info. wasn't aware of that. What about if I prefer the default skin?
geposted Sat 01 Jun 19 @ 4:55 am
learn the dark art of invisible decks...
A deck doesn't have to be on screen to use it, but you have to keep your wits about you.
geposted Sat 01 Jun 19 @ 5:20 am
