Is there a way I can change the skin display from 2 to 4 decks using a keyboard shortcut rather than using the drop down section with my mouse
geposted Sat 08 Jun 19 @ 1:37 am
you can map a custom key in setting -> controlers -> keyboard for that:
setting 'skin' & param_contains "/:2" ? load_skin ':4 Decks' : load_skin ':2 Decks'
I use to use CTRL+ALT+LEFT and CTRL+ALT+RIGHT for skin change
same as ALT GR + LEFT and ALT GR + RIGHT
for a pad or a custom button you hve to split both commands
combination does not seems to work
geposted Sat 08 Jun 19 @ 4:19 am
load_skin ':2 Decks' ? load_skin ':4 Decks' : load_skin ':2 Decks'
geposted Sat 08 Jun 19 @ 6:07 am
Fine! I was not aware "load_skin" was a query !
do you know the reason why the sequence
"setting 'skin' & param_contains '/:2' ? ....."
works fine but with load_skin ?
geposted Sat 08 Jun 19 @ 12:37 pm
Not sure to be honest.
geposted Sat 08 Jun 19 @ 1:12 pm
