I don't know if it would be possible or not but a better way to manage frequent singers would be awesome. right now it's just a scroll list, and on a busy night it can be hard to scroll through 30 or 40 singers. Even if it was just a small extension window, that would be very helpful.
Thank you for your time. ^-^
geposted Wed 26 Jun 19 @ 4:53 am
+1
for now you can add the frequent singers as a link in the sideview then select the song and drag it in kraoke link
but the list is not scrollable, and the name disapears when there are many links next some links don't appear
have to resize the split pannel to make them reappear
this way song singer name and key change are keept between sessions and directly added to the karaoke list
note key change can't display, if there are many for the same singer and the same song .... noway
geposted Wed 26 Jun 19 @ 12:12 pm
Precision on making link:
Browse History -> karaoke and select a singer
then click the "Add shortcut" button bottom right the sideview
do it for each frequent singers
clicking sideview option also raise the list, i didn't notice this, this helps
geposted Wed 26 Jun 19 @ 12:44 pm
thank you very much. I will look into this. ^-^
geposted Wed 26 Jun 19 @ 5:10 pm
