Hi, I am having a terrible time trying to get some of my songs set up to play from the start of the song rather than the start of the CBG.
I have tried for hours to try and get this to work how I want it to. Some songs have a small intro without beat, or even just the file has half to 1 beat of noise before the first beat that is causing me an issue. Because when I set a load point to the correct spot, yeah that loads there perfectly, but then when I play the file and hit return to start it goes past the load point to the begining of the CBG. Which then puts it out of sync with other tracks. I have tried cropping the files in audacity and ableton without success. VDJ seems to just add it back somehow, if not all, at least half a beat. Would be nice if I could simply crop the file in the BPM editor. Or when I hit return to start it returns to the load point instead of the start of the CBG. I have attached some screen shots to display the problem. No I havn't, seems I can't, will only allow 1 pic displayed in this window, which is pointless. I need to show at least 2 of the pics to make any sense. So without pics, can you understand what I mean? Can you advise me how to tackle the problem?
geposted Thu 27 Jun 19 @ 6:02 am
Which button do you use to return to start?
If you press cue while the track is playing it should return back to where it started
geposted Thu 27 Jun 19 @ 6:43 am
Shift Cue on my reloop touch
geposted Thu 27 Jun 19 @ 7:05 am
I just had a look at that again. What you say is true, UNLESS you have hit pause first. If pause has been hit then hitting cue drops a cue point.
I always hit pause first.
I had a look at the controller settings. Shift-Cue is go back to start. Cue is Pioneer-Cue, whatever that means?
After a bit of testing, I found that providing pause has not been used, hitting cue takes you back to the last start point, whether that was from a cue point or the load point.
I don't need cue to drop cue points, so how can I change it to only go back to the last start point, even if pause has been used?
geposted Thu 27 Jun 19 @ 7:17 am
