Hi! New to VDJ. I've been searching for the answer to this in old posts but can't find it, maybe because it's not possible. Hope someone can tell me if it is or isn't. I've got 2 tracks loaded at the same BPM. Track 1 is playing and I want Track 2 to start automatically at a point of my choosing, rather than cue it in manually. Is this possible? Thanks!
geposted Wed 10 Jul 19 @ 9:52 pm
Welcome! You’re describing Automix and the Automix editor. I rarely use it but Automix is described here:
https://www.virtualdj.com/manuals/virtualdj/features/automix.html
And the editor here:
https://www.virtualdj.com/manuals/virtualdj/editors/automixeditor.html
geposted Thu 11 Jul 19 @ 12:23 am
Thanks, will check it out
geposted Fri 12 Jul 19 @ 6:28 pm
Use action cues
Stick a cue point at the part of Track 1 where you want Track 2 to begin. and set a cue point on Track 2 where you want this to begin e.g cue 1
Right click on the cue of track 1 and under 'Type' make it an action cue and then enter the action in the macro box.
For example (assuming track 1 is on deck 1 and track 2 is on deck 2)
deck 2 goto_cue 1 & deck 2 play
if you want track one to stop once track 2 starts then simply tell the macro to do that as well
deck 2 goto_cue 1 & deck 2 play & deck 1 stop
this is a very basic way of doing it there are literally tons of things you can do with action cues !
geposted Thu 18 Jul 19 @ 9:48 pm
