Is it possible to get an echo that will ONLY echo a certain frequency??
If not can we get a plug-in that will do this please?
geposted Thu 11 Jul 19 @ 7:55 pm
You csn use the low pasd and high pass filter options of the echo effect to limit the range.
It's not a very strong filter but depending on what you need it could be ok
geposted Fri 12 Jul 19 @ 3:37 am
Ok cool, I’ll check it out.
Let’s say I get it to work how I want, how do I copy the dll since it’s a factory fix.
geposted Fri 12 Jul 19 @ 2:57 pm
There is no dll to copy.
Settings are stored in Documents\VirtualDJ\Plugins\native_Echo.ini so you can copy this file if you want to copy the settings.
geposted Fri 12 Jul 19 @ 3:28 pm
