Topic: DDJSX3 Inner LEDs on Jogwheels
Been tinkering with the DDJSX3 jog inner red leds mapping allday to no avail so far , i'm trying to get them to behave as they do in serato , so they indicate the track progress when playing, one to start then all four as the track draws to an end ....can anyone help with how the mapper should look to achieve this please :-)
geposted Tue 16 Jul 19 @ 2:23 pm
Are you talking about the 4 red inner quadrant lines ? Its just 4 to be accurate on the song position. Are you sure its how they work in Serato ?
This is part of the Pioneer Manual..
Anyways, about what you asked for, you can try :
LED_JOG_INNER to map as .. song_pos
geposted Tue 16 Jul 19 @ 3:14 pm
