Topic: MCX8000 Controller not showing in "AUDIO" settings.
Hello, I have just got a new Mac Book pro. I have connected and I am able to control VDJ through the MAC. However I am not getting any sounds through monitors and I also don't have DENONMCX8000 as a card selection in the "Audio" settings. Please help. I see Denon showing in "Controllers" but once clicked I do not see the Denon card showing in "Audio" as it should.
geposted Tue 16 Jul 19 @ 8:44 pm
Even if there is no special button in the Audio tab for the MCX8000 (which it should), are you still able to manually select the MCX8000 sound card from the drop-downs and manually create the setup as shown here https://virtualdj.com/manuals/hardware/denon/mcx8000/setup.html , or not available at all and all you get is your computer's built-in sound card ?
Can you also check Audio MIDI Setup (from Utilities) and see if the MCX8000 sound card is there ? (screenshots would help)
You need firmware and drivers for windows
https://www.denondj.com/downloads
MCX8000
Windows Driver
v1.0.5
Download
31.3 MB
Firmware
v2.1
Download
5.1 MB
User Guide
v1.1
Download
5 MB
Quickstart Guide
v1.2
Download
6.9 MB
Firmware Update Instructions
Download
390.4 KB
MIDI Command List
v1.0
Download
76.6 KB
Why? The OP states he is using a new MacBook Pro. What use would Windows drivers be?
I am having the same issue with a macbook pro, OS 14.4. VDJ8 will not see it in the audio settings.
Side note - VDJ8 will see my DDJ-SB2 with no issues. Mac osx 10.14.4, MacBook Pro
I have the same problem.
I tried on my MacBook which is OS Catalina 10.15.6 version and on my Mac mini OS High Sierra 10.13.6 version.
both of them have the same problem.
I install the mac driver from Denon website but nothing change.
can anyone help me pls?
MCX8000
Windows Driver
v1.0.5
Download
31.3 MB
Firmware
v2.1
Download
5.1 MB
User Guide
v1.1
Download
5 MB
Quickstart Guide
v1.2
Download
6.9 MB
Download
390.4 KB
MIDI Command List
v1.0
Download
76.6 KB
I try that but still don’t work
I see you are on Windows. If the driver is properly installed, you should see "Hardware Connected" .. when opening Control Panel from C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Denon DJ\MCX8000
In your Account stats i see .. :asio-Denon DJ MCX8000 ASIO:0/0 , which means the ASIO driver is not reporting any channels, probably not present/blocked - not sure.
