Topic: 10 min limit ???
IMDEDJPRO InfinityMember since 2010
Hi I pay for the monthly $19 dollar subscription and it was working fine. Recently I keep Getting cut off and a message that says there’s a 10 min limit without a license . I’m using a denon mc2000 AND I’m paying for a monthly license . Any help is greatly appreciated since I keep getting an email that says
“With Version8 is no longer a license key needed, because everything is now account related.
So please just download the V8 from here and enter your accountname and password. That's it :-)”
geposted Wed 17 Jul 19 @ 12:36 pm
It looks like your current acount to have a pro-infinity license
If you connect to VDJ using this account you wouldn't have any limitation
Monthly $19 subscription is an alternative to the one-time purchase VirtualDJ Pro Infinity
It's strange you get both at the same time
geposted Wed 17 Jul 19 @ 12:58 pm
I do connect using my acct and as mentioned it use to work fine. Now I’m getting locked after 10 mins
geposted Wed 17 Jul 19 @ 1:05 pm
What do you see in VirtualDJ Settings->LICENSES tab under "Current licenses" ?
geposted Wed 17 Jul 19 @ 2:13 pm
Are you perhaps trying to use a different audio config to the default controller one?
geposted Wed 17 Jul 19 @ 4:17 pm
With a Pro subscription or Pro Infinity, any audio setup is supported, so that cant be the issue.
Please contact Support to get further assistance on this.
geposted Thu 18 Jul 19 @ 3:44 pm
